[GRASS-dev] Re: Building GRASS/QGIS with MSYS
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Tue Feb 5 05:39:48 EST 2008
> Now the question: is with-libtool necessary for gdal? because there are
It's not. In fact, the GDAL developers recommend turning it off for
MSYS. As a consequence, you have to re-link the GDAL library files
after successful compilation in order to get shared Win32 DLLs.
> some things not clear to me about this passage.. after building gdal
> level one, it says:
> ./configure --with-ngpython --with-xerces=/local/ --with-jasper=/local/
> --with-grass=/local/grass-6.3.cvs/ --with-pg=/local/pgsql/bin/pg_config.exe
> 1) neither python nor grass and postgresql are install at this step of
> the guide; how could that be? do I really need this "line" and the
> following "sed"?
I guess the guide assumes some software to be available in your MSYS
installation already. Do you require postgresql and python support?
> But also with the following warnings:
> configure: warning: *** Unable to locate iconv() function.
> configure: warning: *** Unable to locate socket() function.
> configure: warning: *** --with-opengl=windows is untested.
> I decided to add Tcl/Tk support to be able to test some new grass
> modules I added before to be "qgis ready";
Those are harmless as long as you don't need internationalized messages
in GRASS.
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
