[GRASS-dev] [GRASS GIS] #38: configure.in: wxwidgets and python
checks
Michael Barton
michael.barton at asu.edu
Tue Feb 5 12:51:23 EST 2008
On Feb 5, 2008, at 10:45 AM, Martin Landa wrote:
> Hi,
> 2008/2/5, Michael Barton <michael.barton at asu.edu>:
>>>> What does --with-wxwidgets do if you set it? What happens if you
>>>> do not?
>>> from the ticket description
>>> It checks
>>> * if wx-config is presented
>>> * wxWidgets version (>=2.8.1 required)
>>> * check for wx/wxprec.h and wx/wxPython/pseudodc.h (wxPython
>>> required too)
>>> The patch also checks for Python.h header if --with-python is given.
>>> for vdigit it meas: it is compiled only when you give --with-python
>>> and --with-widgets, otherwise vdigit would be not compiled.
>>> Martin
>> That's fine Martin. Thanks. I'm trying to find out how it checks. Are
>> the checks generic enough to work with Mac and Windows, or are they
>> still hard coded to Linux locations?
> if you look at gui/wxpython/vdigit/Makefile, only one location is
> still hard-coded, the includes for python
> -I/usr/include/python$(PYTHONVERSION)
> The patch checks for Python.h and include directory, it should work on
> Mac/Windows too.
> Martin
OK, my standard MacPython include directory and Python.h are at /
Library/Frameworks/Python.framework/Versions/2.5/include/Python.h
wx is down a similar path.
Michael
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/
> ~landa *
