[GRASS-dev] Re: [GRASS GIS] #37: r.in.xyz increase region based on
input data
trac at osgeo.org
Tue Feb 5 17:52:23 EST 2008
#37: r.in.xyz increase region based on input data
Reporter: marisn | Owner: hamish
Type: enhancement | Status: assigned
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Changes (by hamish):
* status: new => assigned
* owner: grass-dev at lists.osgeo.org => hamish
* cc: grass-dev at lists.osgeo.org (added)
Comment:
While I do see the merit of the convenience, I am not especially inclined
to have that feature added. IMHO the first r.in.xyz run with -s should be
followed by "g.region n= s= e= w= res= -a" followed by a "r.in.xyz
method=n" and "r.univar map=n" to tune the region extent and resolution to
something suitable before proceeding.
aka the "Eat your vegetables" response.
Besides failing the "do one thing well" test, I think there was some goal
to have only the g.region module be able to change the mapset's region.
(other modules may change it internally for the duration of execution but
that should not affect other modules or the $MAPSET/WIND file)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/37#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
