[GRASS-dev] Re: [GRASS GIS] #37: r.in.xyz increase region based on
input data
trac at osgeo.org
Tue Feb 5 19:09:11 EST 2008
#37: r.in.xyz increase region based on input data
Reporter: marisn | Owner: hamish
Type: enhancement | Status: assigned
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Comment (by epatton):
I wrote a shell script wrapper around 'r.in.xyz -s' specifically to set
set the region bounds to the maximum extent of the input data. The script
also lets you enter in the desired resolution for the g.region call.
Anyone here could probably write a similar one in 5 minutes, which is why
I never posted it before, but I could post it if anyone wants. Where I
work with so much xyz data on a regular basis, it does save me a lot of
"g.region n= s=", etc.
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/37#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
