[GRASS-dev] i.landsat.rgb -p after using i.fusion.brovey
Otto Dassau otto.dassau at gmx.de
Wed Feb 6 10:42:03 EST 2008
i.landsat.rgb -p fails for me with maps created with i.fusion.brovey:
line 138: [: 47.9603: integer expression expected
Attached you find the small changes that make it work at least for me again.
Regards,
 Otto
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080206/9100f814/i.landsat.rgb.bin
