[GRASS-dev] i.landsat.rgb -p after using i.fusion.brovey
Martin Landa
landa.martin at gmail.com
Wed Feb 6 10:53:31 EST 2008
2008/2/6, Otto Dassau <otto.dassau at gmx.de>:
> i.landsat.rgb -p fails for me with maps created with i.fusion.brovey:
> line 138: [: 47.9603: integer expression expected
> Attached you find the small changes that make it work at least for me again.
it seems to be same the issue as (patch already attached).
http://www.nabble.com/i.landsat.rgb-problem-td14917120.html#a14917120
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
