Hello, I just build grass --with-cairo, but when I try to create postscript, pdf or svg output, I only get empty files. I'm on debian etch using the libcairo2 & libcairo2-dev 1.2.4-4 packages. Is this a problem with my cairo implementation or is it a problem in the cairo driver ? Moritz
