[GRASS-dev] Re: [GRASS GIS] #39: r.in.srtm fails to validate zip files
Sat Feb 9 16:25:24 EST 2008
>   Reporter:  kyngchaos  |       Owner:  grass-dev at lists.osgeo.org
>       Type:  defect     |      Status:  new
>   Priority:  major      |   Milestone:  6.3.0
>  Component:  default    |     Version:  unspecified
> Resolution:             |    Keywords:
> Comment (by kyngchaos):
>  I guess my main concerns are:
>   * the "--mime" flag is standard on modern systems - it looks like it.
>   * I've noticed that people tend to avoid the double-dash long versions of
>  flags, but I don't know if there is a technical reason other than less
>  typing.  In this case it avoids confusion in the -i/-I short flag.
>  If there are no objections to "--mime", I'll patch r.in.srtm.
I'd suggest skipping the use of "file" altogether. It isn't a standard
utility on Windows.
I would assume that the filename ending in .zip is at least prima
facie evidence of the file actually being a ZIP file.
