[GRASS-dev] Re: [GRASS GIS] #39: r.in.srtm fails to validate zip
files
William Kyngesburye
woklist at kyngchaos.com
Sat Feb 9 17:40:21 EST 2008
Makes sense. I wonder why it was changed in the past? It used to try
unzipping and check if it failed. Markus?
http://trac.osgeo.org/grass/changeset/19303
On Feb 9, 2008, at 3:25 PM, Glynn Clements wrote:
> GRASS GIS wrote:
>> #39: r.in.srtm fails to validate zip files
>> Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
>> Type: defect | Status: new
>> Priority: major | Milestone: 6.3.0
>> Component: default | Version: unspecified
>> Resolution: | Keywords:
>> Comment (by kyngchaos):
>> I guess my main concerns are:
>> * the "--mime" flag is standard on modern systems - it looks like
>> it.
>> * I've noticed that people tend to avoid the double-dash long
>> versions of
>> flags, but I don't know if there is a technical reason other than
>> less
>> typing. In this case it avoids confusion in the -i/-I short flag.
>> If there are no objections to "--mime", I'll patch r.in.srtm.
> I'd suggest skipping the use of "file" altogether. It isn't a standard
> utility on Windows.
> I would assume that the filename ending in .zip is at least prima
> facie evidence of the file actually being a ZIP file.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
