[GRASS-dev] Re: [GRASS-PSC] GRASS 7 planning
Dylan Beaudette dylan.beaudette at gmail.com
Sun Feb 10 20:41:05 EST 2008
I'll pitch in some time migrating bugs over to trac if that would be helpful.
Dylan
On Feb 9, 2008 4:02 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Hi all.
> Comments in-line.
> 2008/2/9, Markus Neteler <neteler at osgeo.org>:
> > I have added the bugtracker links to
> > http://trac.osgeo.org/grass/wiki/Grass7Planning
> > If there are patches, they need to be tested and applied.
> > If this doesn't happen... we cannot delay forever (luckily higher
> > version numbers are yet free :).
> > > Also there is an unreported bug in NVIZ panel code (switching from
> > > "fly" mode to "eye/center" fail), that I will look into within next
> > > hours. (Exists in 6.3.0RC4 and current svn trunk)
> > Thanks for looking into this!
> Bug description and possible patch here:
> http://trac.osgeo.org/grass/ticket/42
> Still NVIZ UI needs some loving.
> > > I'm NOT proposing to delay 6.3.0. Just pointing out, that current bug
> > > tracking system does not reflect current code quality status.
> > Why do you think so? This would mean than many bugs are missing the
> > the trackers? Are you sure about that?
> Sorry for being unclear - I was pointing out, that we currently have
> three bugtrackers and current code quality can NOT be qualified basing
> only on latest(current) bugtracker bugs, as there are some bugs left
> in previous trackers.
> > > Release 6.3.0 -> make old bugtracker cleaning day -> backport from 6.4
> > > -> release 6.3.1 ?
> > Ideally yes. In the real world the old bugtracker cleaning day didn't happen
> > yet although proposed...
> Then let's try to make another bug trigage day after 6.3.0 release
> (till we succeed).
> > Markus
> Maris.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
