[GRASS-dev] Re: [GRASS GIS] #38: configure.in: wxwidgets and
python checks
Glynn Clements
glynn at gclements.plus.com
Mon Feb 11 16:01:18 EST 2008
Ivan Shmakov wrote:
> > You can currently run with --with-python=/usr/bin/python2.5 to
> > force using version 2.5.
> BTW, there're some Python-related Autoconf code in Automake and
> in the Autoconf Macro Archive, e. g.:
> $ dpkg -S python.m4
> autoconf-archive: /usr/share/autoconf-archive/ax_boost_python.m4
> autoconf-archive: /usr/share/autoconf-archive/ax_python.m4
> autoconf-archive: /usr/share/autoconf-archive/ax_with_python.m4
> autoconf-archive: /usr/share/autoconf-archive/az_python.m4
> automake: /usr/share/aclocal-1.10/python.m4
> At the first glance, `az_python.m4' seems to be the most
> suitable. Apparently, it doesn't depend on `python-config', but
> accesses the same configuration storage using the ways native to
> Python.
> Is this check suitable for GRASS?
Why use anything other than python-config? If some other mechanism
produces the same result, there's no benefit; if it produces a
different result, it's presumably wrong.
If there's a standardised way to do something, using any other
mechanism is usually a maintenance headache waiting to happen.
