[GRASS-dev] Building gui/wxpython/vdigit fails on Gentoo
Martin Landa landa.martin at gmail.com
Sat Feb 16 12:10:20 EST 2008
2008/2/16, Michael Barton <michael.barton at asu.edu>:
> This is confusing to me. wx.PseudoDC has been a part of wxPython code
> for quite some time. We're using it as a basis for the main map display.
right, it is the reason why I am using PseudoDC class in digitizer.
Since C++ PseudoDC class is not part of wxWidgets (should be in 2.9)
but only of wxPython it causes some problems in compilation process.
You need to define also includes/libs for wxPython (C++ code).
> Also, since you use $GISBASE, I assume that you mean that the driver
> must be compiled AFTER running make and make install. Correct?
Yes, I will change README notes to something more reasonable.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
