[GRASS-dev] Building gui/wxpython/vdigit fails on Gentoo
Michael Barton
michael.barton at asu.edu
Sat Feb 16 14:32:24 EST 2008
On Feb 16, 2008, at 10:10 AM, Martin Landa wrote:
> Hi,
> 2008/2/16, Michael Barton <michael.barton at asu.edu>:
>> This is confusing to me. wx.PseudoDC has been a part of wxPython code
>> for quite some time. We're using it as a basis for the main map
>> display.
> right, it is the reason why I am using PseudoDC class in digitizer.
> Since C++ PseudoDC class is not part of wxWidgets (should be in 2.9)
> but only of wxPython it causes some problems in compilation process.
> You need to define also includes/libs for wxPython (C++ code).
So we make a link to the wxPython includes and libs so that C++ can
find the PseudoDC pieces it needs?
Michael
>> Also, since you use $GISBASE, I assume that you mean that the driver
>> must be compiled AFTER running make and make install. Correct?
> Yes, I will change README notes to something more reasonable.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/
> ~landa *
