[GRASS-dev] Building gui/wxpython/vdigit fails on Gentoo
Martin Landa landa.martin at gmail.com
Sat Feb 16 14:36:47 EST 2008
2008/2/16, Michael Barton <michael.barton at asu.edu>:
> >> This is confusing to me. wx.PseudoDC has been a part of wxPython code
> >> for quite some time. We're using it as a basis for the main map
> >> display.
> > right, it is the reason why I am using PseudoDC class in digitizer.
> > Since C++ PseudoDC class is not part of wxWidgets (should be in 2.9)
> > but only of wxPython it causes some problems in compilation process.
> > You need to define also includes/libs for wxPython (C++ code).
> So we make a link to the wxPython includes and libs so that C++ can
> find the PseudoDC pieces it needs?
yes, since PseudoDC is not (yet) part of wxWidgets it is required (at
least for pseudodc.h and given shared library (_gdi_.so)).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
