[GRASS-dev] [GRASS GIS] #55: NVIZ. Shrinking of the surface when the surface resolution is increased
GRASS GIS trac at osgeo.org
Tue Feb 19 05:34:33 EST 2008
 Reporter:  clerici  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  6.4.0
Component:  default  |     Version:  6.2.3
 Keywords:           |
 When the resolution of the current surface is increased (both in Coarse
 Style and in Fine representations), the dimension of the surface is
 progressively reduced. [[BR]]
 The shrinking can be better evaluated by superimposing a vector map, as in
 the attacched examples.[[BR]]
 Example 1. Fine resolution =5[[BR]]
 Example 2. Fine resolution =10
Ticket URL: <http://trac.osgeo.org/grass/ticket/55>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
