[GRASS-dev] g.mremove bug?
Ivan Shmakov
ivan at theory.asu.ru
Thu Feb 21 23:40:10 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>> $ g.mlist rast pattern="out_ST*" | sed -e s/^/rast=/ | xargs g.remove
>> This variant runs `g.remove' in ``batches'', supplying each time
>> just enough arguments to reasonably fill the limited command line
>> space.
>> The use of `xargs' is safe as long as the arguments don't contain
>> any of the following characters:
> That isn't a problem; GRASS map names aren't allowed to contain any
> of those characters.
ACK, thanks.
> The more fundamental problem with using xargs is that the GRASS
> parser requires multiple "answers" for any given option to be
> separated by commas, not spaces.
Does it? IIUC, the following commands are completely equivalent
as long as the GRASS parser is concerned:
$ g.remove rast=foo,bar
$ g.remove rast=foo rast=bar
> That effectively requires g.mremove to collate names itself.
> Invoking g.remove once per map is simpler, but it's also inefficient.
Huh? Even simpler than the following?
may_be_foo () {
if [ -z "$2" ]; then
return
fi
g.mlist $regex type="$1" mapset="$MAPSET" pattern="$2" \
| sed -e s,^,"$1"=,
may_be_foo rast "$r"
may_be_foo rast3d "$r3"
may_be_foo vect "$v"
may_be_foo icon "$i"
may_be_foo labels "$l"
may_be_foo region "$rg"
may_be_foo group "$g"
may_be_foo 3dview "$d"
} | xargs g.remove
But actually, since POSIX `xargs' lacks `-r', it's necessary to
check for the empty list case, e. g.:
} > "$tmp"
if grep -q . -- "$tmp"; then
xargs g.remove < "$tmp"
fi
