[GRASS-dev] g.mremove bug?
    Ivan Shmakov
    ivan at theory.asu.ru
    Fri Feb 22 01:41:20 EST 2008
	May I suggest the following patch?
scripts/g.mremove/g.mremove: Fixed: don't hit the OS command line limits
by using `xargs'.
(nntp://news.gmane.org/gmane.comp.gis.grass.devel/25028)
--- a/scripts/g.mremove/g.mremove
+++ b/scripts/g.mremove/g.mremove
@@ -119,100 +119,40 @@ if [ $force -eq 1 ] ; then
    g.message "Forcing ..."
 fi
-r=$GIS_OPT_RAST
-r3=$GIS_OPT_RAST3D
-v=$GIS_OPT_VECT
-i=$GIS_OPT_ICON
-l=$GIS_OPT_LABEL
-rg=$GIS_OPT_REGION
-g=$GIS_OPT_GROUP
-d=$GIS_OPT_DVIEW
-if [ -n "$r" ] ; then
-    rast=`g.mlist $regex type=rast sep=, mapset=$MAPSET pattern="$r"`
-fi
-if [ -n "$r3" ] ; then
-    rast3d=`g.mlist $regex type=rast3d sep=, mapset=$MAPSET pattern="$r3"`
-fi
-if [ -n "$v" ] ; then
-    vect=`g.mlist $regex type=vect sep=, mapset=$MAPSET pattern="$v"`
-fi
-if [ -n "$i" ] ; then
-    icon=`g.mlist $regex type=icon sep=, mapset=$MAPSET pattern="$i"`
-fi
-if [ -n "$l" ] ; then
-    labels=`g.mlist $regex type=labels sep=, mapset=$MAPSET pattern="$l"`
-fi
-if [ -n "$rg" ] ; then
-    region=`g.mlist $regex type=region sep=, mapset=$MAPSET pattern="$rg"`
-fi
-if [ -n "$g" ] ; then
-    group=`g.mlist $regex type=group sep=, mapset=$MAPSET pattern="$g"`
-fi
-if [ -n "$d" ] ; then
-    dview=`g.mlist $regex type=3dview sep=, mapset=$MAPSET pattern="$d"`
-fi
-found=
-if [ "$rast" ] ; then
-	found=1
-	rast="rast=$rast"
-fi
-if [ "$rast3d" ] ; then
-	found=1
-	rast3d="rast3d=$rast3d"
-fi
-if [ "$vect" ] ; then
-	found=1
-	vect="vect=$vect"
-fi
-if [ "$icon" ] ; then
-	found=1
-	icon="icon=$icon"
-fi
-if [ "$labels" ] ; then
-	found=1
-	labels="labels=$labels"
-fi
-if [ "$region" ] ; then
-	found=1
-	region="region=$region"
-fi
-if [ "$group" ] ; then
-	found=1
-	group="group=$group"
-fi
-if [ "$dview" ] ; then
-	found=1
-	dview="3dview=$dview"
-fi
-if [ ! "$found" ] ; then
+tmp="$(g.tempfile pid=$$)"
+may_be () {
+    if [ -z "$2" ]; then
+        return
+    fi
+    g.mlist $regex type="$1" mapset="$MAPSET" pattern="$2" \
+        | sed -e s,^,"$1"=,
+    may_be rast     "$GIS_OPT_RAST"
+    may_be rast3d   "$GIS_OPT_RAST3D"
+    may_be vect     "$GIS_OPT_VECT"
+    may_be icon     "$GIS_OPT_ICON"
+    may_be labels   "$GIS_OPT_LABEL"
+    may_be region   "$GIS_OPT_REGION"
+    may_be group    "$GIS_OPT_GROUP"
+    may_be 3dview   "$GIS_OPT_DVIEW"
+} > "$tmp"
+if ! grep -q . -- "$tmp" ; then
 	g.message -e "No data found."
 	exit 1
 fi
 if [ $force -eq 0 ] ; then
     g.message "The following files would be deleted:"
-    echo "g.remove $rast $rast3d $vect $icon $labels $region $group $dview"
+    ## FIXME: should probably use `g.message'
+    cat -- "$tmp"
     g.message message=""
     g.message "You must use the force flag to actually remove them. Exiting."
     exit 0
 fi
-exec g.remove $rast $rast3d $vect $icon $labels $region $group $dview
+xargs g.remove < "$tmp"
