[GRASS-dev] Re: [GRASS GIS] #57: v.digit compilation failure [also seems to affect v.edit]
GRASS GIS trac at osgeo.org
Sat Feb 23 14:33:33 EST 2008
  Reporter:  glynn   |       Owner:  martinl
      Type:  defect  |      Status:  assigned
  Priority:  major   |   Milestone:  6.3.0
 Component:  Python  |     Version:  svn-trunk
Resolution:          |    Keywords:  v.digit v.edit
Changes (by martinl):
  * status:  new => assigned
  * owner:  grass-dev at lists.osgeo.org => martinl
 * cc: grass-dev at lists.osgeo.org (added)
Comment:
 Replying to [comment:2 glynn]:
 > If the header is to be public, e.g. because third-party modules may wish
 to use vedit.h, it should be installed into $(ARCH_INCDIR) by
 lib/vector/vedit/Makefile. See e.g. lib/rst/qtree/Makefile for an example.
 The header should then be referenced as <grass/vedit.h>.
 > If the header (and thus the library) is for internal use only, then
 leave it where it is and add e.g.:
 > EXTRA_CFLAGS = -I../../../lib/vector/vedit
 > to the Makefile for any module which uses it. The header should be
 referenced as just <vedit.h>.
 I changed the header to be public (it could be also used by QGIS vdigit
 port, etc.). I moved vedit.h to 'include' directory. If this solution is
 reasonable I will backported the changes to branch for 6.3.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/57#comment:4>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
