[GRASS-dev] Re: [GRASS GIS] #57: v.digit compilation failure [also
seems to affect v.edit]
trac at osgeo.org
Wed Feb 27 14:43:41 EST 2008
#57: v.digit compilation failure [also seems to affect v.edit]
Reporter: glynn | Owner: martinl
Type: defect | Status: closed
Priority: major | Milestone: 6.3.0
Component: Python | Version: svn-trunk
Resolution: fixed | Keywords: v.digit v.edit
Changes (by martinl):
* status: assigned => closed
* resolution: => fixed
Comment:
Replying to [comment:1 dylan]:
> Is there anyway to specify the direct path to vedit.h now that it lives
in /lib/vector/vedit.h ? Not sure if this is a robust approach, but it
compiles. See attached file
veditlib has been moved to lib/vector/vedit (also backported to
releasebranch_6_3). Seems to be solved, closing the ticket. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/57#comment:5>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
