[GRASS-dev] failure to compile v.class on Mac OS X
Michael Barton
michael.barton at asu.edu
Sun Feb 24 12:07:18 EST 2008
I just tried to compile GRASS from SVN trunk. v.class didn't compile,
so I went to the v.class folder and ran make from there. Here is the
error.
Did I miss a step or does something need to be changed in v.class?
Michael
Errors in:
/Users/cmbarton/grass_dev/grass_src/gui/wxpython/vdigit
/Users/cmbarton/grass_dev/grass_src/vector/v.class
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you
will
also get errors from anything which uses the library.
Finished compilation: Sun Feb 24 09:53:30 MST 2008
make: *** [default] Error 1
cmb-MBP-2:~/grass_dev/grass_src cmbarton$ cd vector
cmb-MBP-2:~/grass_dev/grass_src/vector cmbarton$ cd v.class
cmb-MBP-2:~/grass_dev/grass_src/vector/v.class cmbarton$ make
make: *** No rule to make target `/Users/cmbarton/grass_dev/grass_src/
dist.i686-apple-darwin8.11.1/lib/libgrass_arraystats.dylib', needed
by `/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/
bin/v.class'. Stop.
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080224/c8e81802/attachment.html
