[GRASS-dev] failure to compile v.class on Mac OS X
Martin Landa
landa.martin at gmail.com
Sun Feb 24 12:17:29 EST 2008
2008/2/24, Michael Barton <michael.barton at asu.edu>:
> I just tried to compile GRASS from SVN trunk. v.class didn't compile, so I
> went to the v.class folder and ran make from there. Here is the error.
> Did I miss a step or does something need to be changed in v.class?
You need to compile manually arraystatslib first
cd lib/arraystats
make
BTW: maybe Makefiles could be updated to compile
arraystatslib/v.class/d.thematic.area by default
Martin
> Errors in:
> /Users/cmbarton/grass_dev/grass_src/gui/wxpython/vdigit
> /Users/cmbarton/grass_dev/grass_src/vector/v.class
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Sun Feb 24 09:53:30 MST 2008
> make: *** [default] Error 1
> cmb-MBP-2:~/grass_dev/grass_src cmbarton$ cd vector
> cmb-MBP-2:~/grass_dev/grass_src/vector cmbarton$ cd v.class
> cmb-MBP-2:~/grass_dev/grass_src/vector/v.class cmbarton$
> make
> make: *** No rule to make target
> `/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/lib/libgrass_arraystats.dylib',
> needed by
> `/Users/cmbarton/grass_dev/grass_src/dist.i686-apple-darwin8.11.1/bin/v.class'.
> Stop.
> ____________________
> C. Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
