[GRASS-dev] problem regarding the display of map
Arun verma kumar.arun417 at gmail.com
Mon Feb 25 06:49:38 EST 2008
hi,
i convert the raster map to vector map and the name of new vect map is
map_tf_v
but when i use the display command i am getting following error
g.region vect=map_tf_v
ERROR: Cannot open old vector map_tf_v at PERMANENT on level 2
 d.vect map=tgr_shp
The bounding box of the map is outside the current region, nothing drawn.
how can i display the map...???
thanks & regards
Arun K Verma
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080225/0c4d640f/attachment.html
