[GRASS-dev] way to create PROJ_INFO and PROJ_UNITS
Glynn Clements
glynn at gclements.plus.com
Mon Feb 25 11:43:23 EST 2008
andrea antonello wrote:
> Hi, assume I create a location from outside GRASS and need to create
> the PROJ_INFO and PROJ_UNITS files, since without proj there is no way
> to do that.
> Is there a way to create those file through g.proj from null, best if
> supplying the epsg code?
g.proj -c epsg=...
