[GRASS-dev] R: GEOS, PostgreSQL and SQLite: needed in GDAL?
cmh cmh999 at gmail.com
Wed Feb 27 03:47:13 EST 2008
I seem to have a problem with grass which seems to be connected to this
topic:
I can use sqlite (v.connect and also operations with the sqlite.db work
fine) as well as r.in.gdal functions, v.db.execute and most other gras
functions.
But with all of these functions I get an error message saying "command not
found":
db.in.ogr
v.db.join
At the moment I am trying to join a .csv table to an existing vector
attribute table and don't get there.
do you know what's wrong?
Regards,
Matthias
View this message in context: http://www.nabble.com/GEOS%2C-PostgreSQL-and-SQLite%3A-needed-in-GDAL--tp15352123p15707530.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
