[GRASS-dev] R: GEOS, PostgreSQL and SQLite: needed in GDAL?
Moritz Lennert mlennert at club.worldonline.be
Wed Feb 27 08:14:17 EST 2008
On 27/02/08 09:47, cmh wrote:
> Hi,
> I seem to have a problem with grass which seems to be connected to this
> topic:
> I can use sqlite (v.connect and also operations with the sqlite.db work
> fine) as well as r.in.gdal functions, v.db.execute and most other gras
> functions.
> But with all of these functions I get an error message saying "command not
> found":
> db.in.ogr
> v.db.join
> At the moment I am trying to join a .csv table to an existing vector
> attribute table and don't get there.
> do you know what's wrong?
You will have to tell us a bit more for us to be able to help you: which
OS, which version of GRASS, how did you install it, etc.
Moritz
