[GRASS-dev] Manpage HTML markup consistency
Hamish
hamish_b at yahoo.com
Wed Feb 27 15:09:43 EST 2008
Glynn:
> The real problem is that the format of those files
> isn't documented anywhere. Generic HTML documentation doesn't help,
> because g.html2man doesn't understand arbitrary HTML, nor will any
> replacement.
> If you're going to settle on some subset of HTML as the source
> language, you need to specify exactly which subset that is.
http://trac.osgeo.org/grass/browser/grass/trunk/tools/g.html2man/htmltags.txt
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
