[GRASS-dev] Manpage HTML markup consistency
Thu Feb 28 06:08:04 EST 2008
Hamish wrote:
> > The real problem is that the format of those files
> > isn't documented anywhere. Generic HTML documentation doesn't help,
> > because g.html2man doesn't understand arbitrary HTML, nor will any
> > replacement.
> > If you're going to settle on some subset of HTML as the source
> > language, you need to specify exactly which subset that is.
> http://trac.osgeo.org/grass/browser/grass/trunk/tools/g.html2man/htmltags.txt
It isn't just an issue of which tags, but the syntax of those tags.
E.g. HTML allows line breaks in the middle of a tag, and it allows
literal < and > characters in an attribute value. g.html2man doesn't
cope with either of those (most ad-hoc parsers don't).
There's also the issue of semantics, e.g. how those tags get
translated to nroff, how to link to related documentation, etc.
