[GRASS-dev] [GRASS GIS] #75: v.db.join incorrectly uses
v.db.connect and is broken for multi-layered vectors
trac at osgeo.org
Fri Feb 29 11:36:46 EST 2008
#75: v.db.join incorrectly uses v.db.connect and is broken for multi-layered
vectors
Reporter: tvrusso | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
I attempted to use v.db.join to join a table to the second layer of a
vector that had two layers (two tables connected to it). v.db.join gave
me error messages from db.describe reporting that "<sqlite> is not a valid
parameter" and another reporting that the path to my sqlite database is
not a valid parameter. It turns out that
what was really wrong was that the "driver" and "database" variables that
are set in
v.db.join:
driver="`v.db.connect -g $GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d' '
-f5`"
database="`v.db.connect -g $GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d' '
-f4`"
on lines 76 and 77 are improperly set to "sqlite sqlite" and
"/my/sqlite/db /my/sqlite/db" --- that is, two copies of each are stored
in the variable. That's because according to the man page, v.db.connect
IGNORES the "layer=" option with the "-g" option and reports all database
connections. Since I have two layers, the commands above produce two
copies of the data, and later, when $driver and $database are used in
command lines they cause problems.
Instead of using layer= to try to select the database and driver with
v.db.connect, a more convoluted command line might be necessary, as for
example:
driver=`v.db.connect -g $GIS_OPT_MAP | head -n $GIS_OPT_LAYER | tail -1 |
cut -d' ' -f5`"
I tested out that kind of modification and it does appear to address the
issue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/75>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
