[GRASS-dev] Re: [GRASS GIS] #75: v.db.join incorrectly uses v.db.connect and is broken for multi-layered vectors
GRASS GIS trac at osgeo.org
Fri Feb 29 16:59:21 EST 2008
vectors
  Reporter:  tvrusso  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  closed
  Priority:  major    |   Milestone:  6.3.0
 Component:  default  |     Version:  unspecified
Resolution:  fixed    |    Keywords:
Changes (by hamish):
  * status:  new => closed
  * resolution:  => fixed
  * milestone:  6.4.0 => 6.3.0
Comment:
 this should be fixed now in SVN, r30404.
 instead of head | tail I used 'grep "^$GIS_OPT_LAYER "'. I see v.db.update
 does something similar with 'grep -w "$GIS_OPT_LAYER"'. Either way will do
 I guess.
 please test & report back.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/75#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
