[GRASS-dev] table only creation in v.in.ascii
Martin Landa
landa.martin at gmail.com
Thu Jan 10 10:10:16 EST 2008
hi,
it is better to create one diff file instead of bunch of them, e.g.
svn diff vector/v.in.ascii > v-in-ascii.diff
sorry for bothering you:-)
Martin
2008/1/10, Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de>:
> Alright, here is the patches vor v.in.ascii.
> Cheers,
> Benjamin
> Benjamin Ducke wrote:
> > Unfortunately, it returns DB_OK.
> > There seems to be some caching going on which I don't quite
> > understand at the moment.
> > Starting and stopping the db driver in the right sequence seems
> > to be important.
> > Anyway, I solved the problem by doing the deletion at an earlier
> > point in the program.
> > Everything seems to work OK now. I'll do some tests with more
> > complex tables, then post a patch.
> > Benjamin
> > Moritz Lennert wrote:
> >> On 10/01/08 13:52, Benjamin Ducke wrote:
> >>> OK, I have it almost working except for one annoyance:
> >>> If the table already exists, then --o should allow the user to
> >>> overwrite it. Thus, I check for that flag and delete the old
> >>> table, if it exists, using:
> >>> db_delete_table ( connection.driverName, connection.databaseName,
> >>> new->answer );
> >>> But even so, the next call to
> >>> db_execute_immediate()
> >>> complains about the table still being there and creation of the
> >>> new table fails.
> >>> I suppose that db_delete_table() does not delete the table immediately?
> >> db_delete_table() sends a "drop table XYZ" sql query to the database
> >> backend, so it should delete the table.
> >> Launching
> >> echo "drop table ggg" | db.execute
> >> followed by
> >> echo "create table ggg (cat int, value double)" | db.execute
> >> works without a problem.
> >> What does db_delete_table return ?
> >> Moritz
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Benjamin Ducke, M.A.
> Archäoinformatik
> (Archaeoinformation Science)
> Institut für Ur- und Frühgeschichte
> (Inst. of Prehistoric and Historic Archaeology)
> Christian-Albrechts-Universität zu Kiel
> Johanna-Mestorf-Straße 2-6
> D 24098 Kiel
> Germany
> Tel.: ++49 (0)431 880-3378 / -3379
> Fax : ++49 (0)431 880-7300
> www.uni-kiel.de/ufg
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
