[GRASS-dev] table only creation in v.in.ascii
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Jan 10 09:56:36 EST 2008
Alright, here is the patches vor v.in.ascii.
Cheers,
Benjamin
Benjamin Ducke wrote:
> Unfortunately, it returns DB_OK.
> There seems to be some caching going on which I don't quite
> understand at the moment.
> Starting and stopping the db driver in the right sequence seems
> to be important.
> Anyway, I solved the problem by doing the deletion at an earlier
> point in the program.
> Everything seems to work OK now. I'll do some tests with more
> complex tables, then post a patch.
> Benjamin
> Moritz Lennert wrote:
>> On 10/01/08 13:52, Benjamin Ducke wrote:
>>> OK, I have it almost working except for one annoyance:
>>> If the table already exists, then --o should allow the user to
>>> overwrite it. Thus, I check for that flag and delete the old
>>> table, if it exists, using:
>>> db_delete_table ( connection.driverName, connection.databaseName,
>>> new->answer );
>>> But even so, the next call to
>>> db_execute_immediate()
>>> complains about the table still being there and creation of the
>>> new table fails.
>>> I suppose that db_delete_table() does not delete the table immediately?
>> db_delete_table() sends a "drop table XYZ" sql query to the database
>> backend, so it should delete the table.
>> Launching
>> echo "drop table ggg" | db.execute
>> followed by
>> echo "create table ggg (cat int, value double)" | db.execute
>> works without a problem.
>> What does db_delete_table return ?
>> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080110/9ec84ac6/description.html-0001.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080110/9ec84ac6/in.c-0001.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080110/9ec84ac6/local_proto.h-0001.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080110/9ec84ac6/points.c-0001.bin
