[GRASS-dev] Re: [GRASS-trac] #18: Grass63 -wx gui function r.in.xyz
form not updating input fields.
GRASS-trac
trac at osgeo.org
Sun Jan 13 08:03:44 EST 2008
#18: Grass63 -wx gui function r.in.xyz form not updating input fields.
Reporter: brian | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: r.in.xyz wxgrass
Changes (by martinl):
* milestone: 6.3.0 => 6.4.0
Comment:
Replying to [ticket:18 brian]:
> First import cmd
> r.in.xyz input=/home/xxxx/data/mbes_comp_200m_grid.xyz
output=mbes_comp_200m fs=,
> Second import cmd should have been:
> r.in.xyz input=/home/xxxx/data/mbes_comp_50m_grid.xyz
output=mbes_comp_50m fs=,
> Second import cmd was as follows:
> Also tried to exec the correct second import command from the layer
manager CMD > interface. Unfortunately the command output showed that it
still had the input file name from the first import.
Sorry, I do not fully understand, I launched r.in.xyz
* select first file
* run the command
* then selected the second file
* run the command again
Everything seems OK for me, from command output tab...
$ r.in.xyz input=/home/martin/src/grass_trunk/in.txt output=r00
Scanning data ...
Writing to map ...
r.in.xyz complete. 0 points found in region.
$ r.in.xyz input=/home/martin/src/grass_trunk/in1.txt output=r01
Scanning data ...
Writing to map ...
Are you using compiled svn-trunk?
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/18#comment:1>
GRASS-trac <http://grass.osgeo.org>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
