[GRASS-dev] Re: [GRASS-trac] #18: Grass63 -wx gui function r.in.xyz form not updating input fields.
GRASS-trac trac at osgeo.org
Sun Jan 13 17:06:42 EST 2008
  Reporter:  brian    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:  r.in.xyz wxgrass
Comment (by brian):
 Hi Martin
 Am using compiled svn-trunk.
 Setup two systems at work with grass_trunk at identical builds (29702),
 one a Ubuntu 7.10 and the other Mandriva 2008.
 I can repeat the fault on the Ubuntu system, however the Mandriva system
 performs the test ok.
 The configure options are different between systems, see attached files.
Ticket URL: <http://trac.osgeo.org/grass/ticket/18#comment:2>
GRASS-trac <http://grass.osgeo.org>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
