[GRASS-dev] why d.vect.thematic won't run on WinGRASS -
d.mon problem
Michael Barton
michael.barton at asu.edu
Thu Jan 24 10:07:33 EST 2008
On Jan 24, 2008, at 2:54 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Thu, 24 Jan 2008 10:53:51 +0000
> From: Glynn Clements <glynn at gclements.plus.com>
> Subject: Re: [GRASS-dev] why d.vect.thematic won't run on WinGRASS -
> d.mon problem
> To: Michael Barton <michael.barton at asu.edu>
> Cc: GRASS developers list <grass-dev at lists.osgeo.org>
> Message-ID: <18328.28223.869808.987628 at cerise.gclements.plus.com>
> Content-Type: text/plain; charset=us-ascii
> Michael Barton wrote:
>>> If you just want d.vect.thematic to work with WinGRASS, changing
>>> it to
>>> use GRASS_RENDER_IMMEDIATE=TRUE instead of "d.mon start=PNG" would
>>> probably be less work than getting monitors working.
>> In fact, we recently had to change d.vect.thematic to set
>> GRASS_RENDER_IMMEDIATE=FALSE so that it's multiple iterations of
>> d.vect would composite in the PNG monitor and then be output as a PNG
>> to the GUI.
> You can use GRASS_PNG_READ=TRUE to have it read an existing file at
> startup, rather than starting with a blank "screen". That way, each
> command will overlay the output from previous commands.
Glynn,
This sounds like it might be a way out of this dilemma. Can you
explain this setting a it more? Also, once all the commands are
overlayed is there someway to get them to output to a PNG or PNM so
that the GUI can pick it up--since we can't do it with d.mon stop=PNG?
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
