[GRASS-dev] why d.vect.thematic won't run on WinGRASS - d.mon problem
Moritz Lennert mlennert at club.worldonline.be
Thu Jan 24 10:24:11 EST 2008
On 24/01/08 16:07, Michael Barton wrote:
> On Jan 24, 2008, at 2:54 AM, grass-dev-request at lists.osgeo.org wrote:
>> Date: Thu, 24 Jan 2008 10:53:51 +0000
>> From: Glynn Clements <glynn at gclements.plus.com>
>> Subject: Re: [GRASS-dev] why d.vect.thematic won't run on WinGRASS -
>>     d.mon    problem
>> To: Michael Barton <michael.barton at asu.edu>
>> Cc: GRASS developers list <grass-dev at lists.osgeo.org>
>> Message-ID: <18328.28223.869808.987628 at cerise.gclements.plus.com>
>> Content-Type: text/plain; charset=us-ascii
>>>> If you just want d.vect.thematic to work with WinGRASS, changing it to
>>>> use GRASS_RENDER_IMMEDIATE=TRUE instead of "d.mon start=PNG" would
>>>> probably be less work than getting monitors working.
>>> In fact, we recently had to change d.vect.thematic to set
>>> GRASS_RENDER_IMMEDIATE=FALSE so that it's multiple iterations of
>>> d.vect would composite in the PNG monitor and then be output as a PNG
>>> to the GUI.
>> You can use GRASS_PNG_READ=TRUE to have it read an existing file at
>> startup, rather than starting with a blank "screen". That way, each
>> command will overlay the output from previous commands.
>> --Glynn Clements <glynn at gclements.plus.com>
> Glynn,
> This sounds like it might be a way out of this dilemma. Can you explain
> this setting a it more? Also, once all the commands are overlayed is
> there someway to get them to output to a PNG or PNM so that the GUI can
> pick it up--since we can't do it with d.mon stop=PNG?
GRASS_RENDER_IMMEDIATE=TRUE always outputs a PNG or PNM file (depending
on the setting of GRASS_PNGFILE. As the manual on the PNG env variables
says: if you set GRASS_PNG_READ to "TRUE", "the PNG driver will
initialize the image from the contents of $GRASS_PNGFILE", i.e. it will
read the contents of $GRASS_PNGFILE and adds the results of your drawing
command to it. The output thus still is $GRASS_PNGFILE.
Moritz
> Michael
> ____________________
> C. Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
