[GRASS-dev] d.out.file: world (wld) file support issue
Markus Neteler neteler at osgeo.org
Fri Jan 25 17:11:09 EST 2008
I wanted to add world file support to d.out.file but it seems that
d.info -g doesn't work correctly (-g just added in SVN) in case that
the "res=" parameter of d.out.file is used. The generated world file
remains identical and thus the resulting map shifted.
What's wrong here? Patch attached to generate the world file.
thanks
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080125/6ebb8560/d_out_file.obj
