[GRASS-dev] d.out.file: world (wld) file support issue
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Jan 25 17:21:24 EST 2008
On Friday 25 January 2008, Markus Neteler wrote:
> Hi,
> I wanted to add world file support to d.out.file but it seems that
> d.info -g doesn't work correctly (-g just added in SVN) in case that
> the "res=" parameter of d.out.file is used. The generated world file
> remains identical and thus the resulting map shifted.
> What's wrong here? Patch attached to generate the world file.
> thanks
> Markus
I am not sure what is wrong, but... would it make sense to use the facillities
for world file creation that GDAL provides ? via r.out.gdal ?
maybe I am not seeing the subtle differences..
cheers,
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
