[GRASS-dev] d.out.file: world (wld) file support issue
Markus Neteler
neteler at osgeo.org
Fri Jan 25 17:27:32 EST 2008
On Jan 25, 2008 11:21 PM, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> On Friday 25 January 2008, Markus Neteler wrote:
> > Hi,
> > I wanted to add world file support to d.out.file but it seems that
> > d.info -g doesn't work correctly (-g just added in SVN) in case that
> > the "res=" parameter of d.out.file is used. The generated world file
> > remains identical and thus the resulting map shifted.
> > What's wrong here? Patch attached to generate the world file.
> > thanks
> > Markus
> I am not sure what is wrong, but... would it make sense to use the facillities
> for world file creation that GDAL provides ? via r.out.gdal ?
> maybe I am not seeing the subtle differences..
I want to write out the *monitor* content with d.out.file (r.out.gdal cannot
do that).
Markus
