[GRASS-dev] d.out.file: world (wld) file support issue
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Jan 25 17:52:47 EST 2008
On Friday 25 January 2008, Markus Neteler wrote:
> On Jan 25, 2008 11:21 PM, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> > > Hi,
> > > I wanted to add world file support to d.out.file but it seems that
> > > d.info -g doesn't work correctly (-g just added in SVN) in case that
> > > the "res=" parameter of d.out.file is used. The generated world file
> > > remains identical and thus the resulting map shifted.
> > > What's wrong here? Patch attached to generate the world file.
> > > thanks
> > > Markus
> > I am not sure what is wrong, but... would it make sense to use the
> > facillities for world file creation that GDAL provides ? via r.out.gdal
> > maybe I am not seeing the subtle differences..
> I want to write out the *monitor* content with d.out.file (r.out.gdal
> cannot do that).
> Markus
right.. (whacks head against table...)
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
