[GRASS-dev] convert 3D polygons or Tins to a DEM?
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Mon Jan 28 04:40:53 EST 2008
I noticed this one too a few days back when I was looking for a
3D hull algorithm. Looks like a promising collection of algorithm
for GRASS.
However, for a quick fix of v.delaunay, as suggested by Helena:
Might it not be enough to replace the 2D distance measure in
v.delaunay with a 3D distance, so it will do the tesselation in
3D space correctly?
I could try and find some time to look into that if you think
it feasible.
Benjamin
Markus Neteler wrote:
> On Jan 28, 2008 9:29 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Fixing large dataset and 3D support problems would be a nice
>> improvement of GRASS vector support :)
> Possibly we need to substitute the algorithm? I found for example
> http://www.qhull.org/
> "Qhull computes the convex hull, Delaunay triangulation, Voronoi
> diagram, halfspace intersection about a point, furthest-site Delaunay
> triangulation, and furthest-site Voronoi diagram. The software runs in
> 2-d, 3-d, 4-d, and higher dimensions. Qhull implements the Quickhull
> algorithm for computing the convex hull. It handles roundoff errors
> from floating point arithmetic. Qhull also computes volumes, surface
> areas, and approximations to the convex hull."
> (seems to be GPL compliant)
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
