[GRASS-dev] d.histogram: x axis ticks labels fixed
Michael Barton
michael.barton at asu.edu
Tue Jan 29 20:39:43 EST 2008
Understood. These python utilities draw to Python canvases, and so
normally need the GUI to run. It may be possible for them to output
to a graphic file too. But they are designed to work in a GUI
environment rather than a command line environment.
I don't advocate ditching d.histogram. In fact, the *easiest* thing
from my standpoint, would be to have a sophisticated and slick C-
graphing module that I just had to call as a command and presto it
creates a graphic file that I can pop into a canvas. But I have some
understand of the complexity of writing this in C or anything else.
That's why to use high level graphing tools to do this.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Jan 29, 2008, at 4:24 PM, Moritz Lennert wrote:
>>> ISTR that we had this debate before, but I would plead for some
>>> basic
>>> graphing functionality to remain available outside of the GUI.
>>> Now since
>>> we have decided that python is going to be the scripting language
>>> in the
>>> future, it is probably reasonable to require it as dependency, but
>>> please make sure that you can also get the results of d.histogram
>>> into a
>>> ps/png file at the command line.
>>> Moritz
>> Moritz,
>> For command line folks, can't you just pipe the results of r.stats
>> into gnuplot? It would probably look better too.
> Probably, but it means another dependency and, more importantly,
> another program to learn.
> But don't you think that it would be possible to separate the GUI
> interface from the actual drawing code (both being in python) and
> thus make the latter accessible also from the command line ?
> Moritz
