[GRASS-dev] d.histogram: x axis ticks labels fixed
Moritz Lennert
mlennert at club.worldonline.be
Wed Jan 30 01:48:32 EST 2008
On 30/01/08 02:39, Michael Barton wrote:
> Understood. These python utilities draw to Python canvases, and so
> normally need the GUI to run. It may be possible for them to output to a
> graphic file too. But they are designed to work in a GUI environment
> rather than a command line environment.
http://matplotlib.sourceforge.net/faq.html#BATCHMODE
> I don't advocate ditching d.histogram. In fact, the *easiest* thing from
> my standpoint, would be to have a sophisticated and slick C-graphing
> module that I just had to call as a command and presto it creates a
> graphic file that I can pop into a canvas. But I have some understand of
> the complexity of writing this in C or anything else. That's why to use
> high level graphing tools to do this.
We do have some C-code which exists. It's just a question of whether we
think that someone will take the time for updating that, or whether we
should profit of the efforts done for the GUI to just have the same
functions also available on the command line (with the additional
advantage of consistency). If python is a required dependency anyhow, I
don't have any religion about a module absolutely having to be in C if
the python version is just as good.
Moritz
