[GRASS-dev] lib fn to convert int color number to RGB values?
Ivan Shmakov ivan at theory.asu.ru
Thu Jan 31 10:33:28 EST 2008
>>>>> Hamish  <hamish_b at yahoo.com> writes:
 > RGBA_Color was recently added (as was RGB support for modules' CLI
 > options) so 1) it could be used to pass RGB arround without having to
 > call the display library and 2) we could handle a color value of
 > 'none' without needing to pass a separate variable or rely on the
 > palette index number set to -1. Currently the alpha channel is just
 > set to 0 or 255 for full-transparency ('none') or full-opacity.
	Could the attached (untested) patch be of any help?
Name: not available
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080131/7cae9505/attachment-0001.bin
