[GRASS-dev] lib fn to convert int color number to RGB values?
Hamish
hamish_b at yahoo.com
Thu Jan 31 17:44:58 EST 2008
Ivan Shmakov wrote:
> $ nl -ba include/gis.h
> 336 typedef struct
> 337 {
> 338 unsigned char r, g, b, a; /* red, green, blue, and alpha
> 339 } RGBA_Color ;
> 340
> 341 typedef RGBA_Color RGB_Color;
> s/RGB_Color/RGBA_Color/ ?
no, the idea there was to be a shortcut for those who wanted to use the
struct but didn't care about alpha and didn't want to cause confusion
in the variable namespace. In those cases the alpha channel is ignored
and treated as an unused superfluous appendage. Perhaps it is of
dubious use, but I don't think anything actually uses it...
you can read some earlier history of RGBA_Color here:
http://article.gmane.org/gmane.comp.gis.grass.devel/12185/
http://thread.gmane.org/gmane.comp.gis.grass.devel/20463/focus=20488
http://thread.gmane.org/gmane.comp.gis.grass.devel/11789/focus=11983
As we should be beginning to focus on stabilizing the grass 6 source,
I would prefer to wait for the upcoming start of grass7 before
retooling the color handling subsystem much more. It may be crusty &
old, but it works and known. Then we can do it once, right, instead of
just bolting new ideas onto the legacy system.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
