[GRASS-dev] Re: [GRASS GIS] #197: sfd support for r.terraflow
trac at osgeo.org
Tue Jul 1 18:53:21 EDT 2008
Reporter: adanner | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: terraflow r.terraflow
Platform: Unspecified | Cpu: Unspecified
Changes (by adanner):
* version: svn-develbranch6 => svn-trunk
* milestone: 6.4.0 => 7.0.0
Comment:
Replying to [comment:6 glynn]:
> Replying to [comment:5 adanner]:
> > If you want, I can throw the code from tflowopt.c back into main.cc
and then you'll get 30+ warning about how terraflow is trying to connect
to the rest of Grass.
> That is my preference.
new patch uploaded. Patch is now against svn-trunk, but the changes can be
merged back to 6.4.0.
I updated the milestone and version tags.
> > This seems excessive, since there currently is no right way to fix a
C-style interface in C++ without bloating the code and making it
unreadable.
> Correct. Which is why the interface needs to be fixed in C; i.e. add the
"const" to the fields of "struct Option" in gis.h. Having the compiler
remind people about this on a regular basis is the best way to make it
happen.
> Actually, I'll look into that side of it now.
Thanks, that eliminates many of the warnings. There are only four left on
options->answer, but I'm content with only four warnings. Fixing those
last four require some tedious buffer creation/copying.
Ticket URL: <http://trac.osgeo.org/grass/ticket/197#comment:8>
