[GRASS-dev] Plan to build Package to use GRASS from R
Rainer M Krug
r.m.krug at gmail.com
Wed Jul 2 10:16:05 EDT 2008
I finally started working on the implementation of grass commands from
R and most of the translation from the the output from
--interface-description is working. I just have one question at the
moment: some flags require "--" and others "-" and I could not fiind
any indication in the
--interface-description output which one uses which.
Any ideas where I can get that info from?
Thanks
Rainer
On Thu, Feb 28, 2008 at 3:11 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> On 28/02/2008, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> >> Rainer:
>> >> These CRAN packages seem to use XML, somewhere there maybe there will
>> >> be
>> >> some useful examples of code for parsing the DTD and using it on the
>> >> XML
>> >> description:
>> >>> names(nn$label)
>> >> [1] "XML" "Ryacas" "StatDataML" "caMassClass" "grImport"
>> >> [6] "odfWeave" "pmml" "rpubchem" "tm"
>> >> The equivalent for Bioconductor, where XML is used for metadata for
>> >> gene
>> >> arrays, there are more packages:
>> >>> names(nn$label)
>> >> [1] "XML" "AnnBuilder" "ChromoViz" "GSEABase"
>> >> [5] "GeneTraffic" "KEGGSOAP" "RSNPper" "Resourcerer"
>> >> [9] "Rintact" "SAGElyzer" "SBMLR" "ScISI"
>> >> [13] "affycoretools" "biocViews" "biomaRt" "flowUtils"
>> >> [17] "simulatorAPMS" "splicegear" "widgetInvoke"
>> >> Hope this helps,
>> > Yes - definitely. I looked at the XML package and it seems to be
>> > usefull. I
>> > will look at how these packages use XML.
>> I think that StatDataML is closest, and probably simplest.
> Thanks - I'll look at it -- the easier the better.
>> Roger
>> > Rainer
>> > Roger
>> >> Roger Bivand
>> >> Economic Geography Section, Department of Economics, Norwegian School
>> >> of
>> >> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>> >> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>> >> e-mail: Roger.Bivand at nhh.no
>> Roger Bivand
>> Economic Geography Section, Department of Economics, Norwegian School of
> Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation Biology (UCT)
> Plant Conservation Unit Department of Botany
> University of Cape Town
> Rondebosch 7701
> South Africa
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Rondebosch 7701
South Africa
