[GRASS-dev] Re: new v.in.geonames: problems with UTF-8 Unicode text
Ivan Shmakov
ivan at theory.asu.ru
Wed Jul 9 13:32:57 EDT 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>> From the above I could conclude that the other RDBMS are generally
>> representing the results of expressions in SELECTs as having one
>> type out of a narrow set of types (in absence of explicit type
>> casts.) This way, SQLite doesn't look much different to those.
>> Or, to put it differently, I see the discussed problem as not being
>> specific to SQLite.
> The problem is that SQLite doesn't type columns, but the values which
> are in them. Typical RDBMS implementations type the columns. IOW,
> dynamic typing (SQLite) versus static typing (everything else).
> This means that, with SQLite, you need at least one row of data to
> determine the types. It also means that if a column is null for that
> particular row, the column will appear to be null.
... Thus requiring up to the whole set of records to be fetched
in order to determine the ``column type''. And if the field is
NULL for all the records, the only sensible behaviour would be
to signal an error.
> It also means that, for VARCHAR columns, you cannot determine the
> maximum width that can be stored in the column.
When retrieving data, the CHAR () and VARCHAR () columns should
be treated as TEXT. When storing data, it may be sensible to
issue a warning (or error) if the value doesn't fit into such a
``declared'' constraint.
>>> One issue is that SQLite doesn't validate the column types. It uses
>>> some heuristics to determine the affinity type, but ultimately it
>>> allows any sequence of words along with an optional size specifier,
>>> e.g.:
>>> CREATE TABLE foo ( i INT, t TEXT, b ROAST BEEF(99) );
>> Of course. So, it becomes the user's responsibility to make sure
>> that the definition of the table in question is compatible with the
>> RDBMS to which it's copied.
>> I guess that much the same way, once the table is defined to use any
>> types specific to an RDBMS implementation, it cannot be readily
>> copied to any other RDBMS.
>> The only SQLite-specific problem that I see there is that it doesn't
>> actually treat the type name as a constraint on the values put into
>> that field. But then, ``garbage in, garbage out'' is the guiding
>> principle.
> Yep. This isn't a problem for tables which are created through the
> DBMI, as we can ensure that it accepts whatever it creates. The
> problem arises if the user creates or modifies tables externally.
Then it becomes the user's responsibility not to exploit this
SQLite-specific feature (or, otherwise, be ready to solve any
inconsistencies that may arise.)
