[GRASS-dev] Re: [GRASS GIS] #197: sfd support for r.terraflow
GRASS GIS trac at osgeo.org
Thu Jul 10 16:47:49 EDT 2008
  Reporter:  adanner  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  Raster   |     Version:  svn-trunk
Resolution:           |    Keywords:  terraflow r.terraflow
  Platform:  All      |         Cpu:  All
Changes (by neteler):
  * platform:  Unspecified => All
  * cpu:  Unspecified => All
  * milestone:  7.0.0 => 6.4.0
Comment:
 Patch backported to 6.4.svn (code is identical) but it fails there with:
 c++ -DELEV_FLOAT -L/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/lib
 -Wl,--export-dynamic  -L/usr/lib64 -Wl,-rpath-
 link,/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/lib -L/usr/lib64
 -o /home/neteler/grass64/dist.x86_64-unknown-linux-gnu/bin/r.terraflow
 OBJ.x86_64-unknown-linux-gnu/FLOAT/main.o  OBJ.x86_64-unknown-linux-
 gnu/FLOAT/common.o  OBJ.x86_64-unknown-linux-gnu/FLOAT/stats.o  OBJ.
 x86_64-unknown-linux-gnu/FLOAT/fill.o  OBJ.x86_64-unknown-linux-
 gnu/FLOAT/types.o  OBJ.x86_64-unknown-linux-gnu/FLOAT/ccforest.o  OBJ.
 x86_64-unknown-linux-gnu/FLOAT/nodata.o  OBJ.x86_64-unknown-linux-
 gnu/FLOAT/plateau.o  OBJ.x86_64-unknown-linux-gnu/FLOAT/direction.o  OBJ.
 x86_64-unknown-linux-gnu/FLOAT/water.o  OBJ.x86_64-unknown-linux-
 gnu/FLOAT/filldepr.o  OBJ.x86_64-unknown-linux-gnu/FLOAT/grid.o  OBJ.
 x86_64-unknown-linux-gnu/FLOAT/genericWindow.o  OBJ.x86_64-unknown-linux-
 gnu/FLOAT/flow.o  OBJ.x86_64-unknown-linux-gnu/FLOAT/sweep.o  OBJ.x86_64-
 unknown-linux-gnu/FLOAT/weightWindow.o -lgrass_gis -lgrass_datetime -lz
 -lm  \
         -lz  -liostream
 OBJ.x86_64-unknown-linux-gnu/FLOAT/main.o: In function `AMI_STREAM':
 /home/neteler/grass64/raster/r.terraflow/IOStream/include/ami_stream.h:203:
 undefined reference to `ami_single_temp_name(std::basic_string<char,
 std::char_traits<char>, std::allocator<char> > const&, char*)'
 OBJ.x86_64-unknown-linux-gnu/FLOAT/fill.o: In function `AMI_STREAM':
 gnu/FLOAT/fill.o:/home/neteler/grass64/raster/r.terraflow/IOStream/include/ami_stream.h:203:
 more undefined references to `ami_single_temp_name(std::basic_string<char,
 std::char_traits<char>, std::allocator<char> > const&, char*)' follow
 OBJ.x86_64-unknown-linux-gnu/FLOAT/ccforest.o: In function `im_buffer':
 /home/neteler/grass64/raster/r.terraflow/IOStream/include/imbuffer.h:84:
 undefined reference to `MEMORY_LOG(std::basic_string<char,
 std::char_traits<char>, std::allocator<char> >)'
 OBJ.x86_64-unknown-linux-gnu/FLOAT/ccforest.o: In function `em_buffer':
 /home/neteler/grass64/raster/r.terraflow/IOStream/include/embuffer.h:440:
 /home/neteler/grass64/raster/r.terraflow/IOStream/include/embuffer.h:449:
 /home/neteler/grass64/raster/r.terraflow/IOStream/include/embuffer.h:455:
 /home/neteler/grass64/raster/r.terraflow/IOStream/include/embuffer.h:462:
 gnu/FLOAT/ccforest.o:/home/neteler/grass64/raster/r.terraflow/IOStream/include/empq_impl.h:1351:
 more undefined references to `MEMORY_LOG(std::basic_string<char,
 std::char_traits<char>, std::allocator<char> >)' follow
 OBJ.x86_64-unknown-linux-gnu/FLOAT/nodata.o: In function `AMI_STREAM':
 OBJ.x86_64-unknown-linux-gnu/FLOAT/plateau.o: In function `AMI_STREAM':
 OBJ.x86_64-unknown-linux-gnu/FLOAT/water.o: In function `AMI_STREAM':
 OBJ.x86_64-unknown-linux-gnu/FLOAT/water.o: In function `im_buffer':
 OBJ.x86_64-unknown-linux-gnu/FLOAT/water.o: In function `em_buffer':
 gnu/FLOAT/water.o:/home/neteler/grass64/raster/r.terraflow/IOStream/include/empq_impl.h:1351:
 OBJ.x86_64-unknown-linux-gnu/FLOAT/flow.o: In function `AMI_STREAM':
 OBJ.x86_64-unknown-linux-gnu/FLOAT/sweep.o: In function `AMI_STREAM':
 OBJ.x86_64-unknown-linux-gnu/FLOAT/sweep.o: In function `im_buffer':
 OBJ.x86_64-unknown-linux-gnu/FLOAT/sweep.o: In function `em_buffer':
 gnu/FLOAT/sweep.o:/home/neteler/grass64/raster/r.terraflow/IOStream/include/empq_impl.h:437:
 collect2: ld returned 1 exit status
 make: *** [/home/neteler/grass64/dist.x86_64-unknown-linux-
 gnu/bin/r.terraflow] Error 1
 [neteler at markus ~]$ uname -a
 Linux markus 2.6.22.18-laptop-1mdv #1 SMP Mon Feb 11 13:53:01 EST 2008
 x86_64 Intel(R) Core(TM)2 CPU         T5500  @ 1.66GHz GNU/Linux
 [neteler at markus ~]$ gcc -v
 Using built-in specs.
 Target: x86_64-mandriva-linux-gnu
 gcc version 4.2.2 20071128 (prerelease) (4.2.2-3.1mdv2008.0)
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/197#comment:12>
