[GRASS-dev] Re: [GRASS GIS] #197: sfd support for r.terraflow
trac at osgeo.org
Thu Jul 10 17:28:40 EDT 2008
Reporter: adanner | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: terraflow r.terraflow
Platform: All | Cpu: All
Comment (by adanner):
Replying to [comment:12 neteler]:
> Patch backported to 6.4.svn (code is identical) but it fails there with:
You may have an old copy of libiostream.a sticking around. I found that
when I ran make clean in the r.terraflow directory, the libiostream.a file
didn't get destroyed and didn't get rebuilt on make, causing similar
linking errors.
try rm ../../dist.<DISTARCH>/lib/libiostream.a from the r.terraflow
directory and see if it builds. I can build in 6.4 with the latest
updates. The patch was originally against 6.4. It should work. I'm on
i686-pc-linux-gnu.
The makefile should probably be modified to remove libiostream.a on make
clean, but I hate messing with makefiles, so I'll leave that to someone
else.
Ticket URL: <http://trac.osgeo.org/grass/ticket/197#comment:13>
