[GRASS-dev] trying to compile wxPython NVIZ
Martin Landa
landa.martin at gmail.com
Tue Jul 15 02:00:34 EDT 2008
2008/7/15 Glynn Clements <glynn at gclements.plus.com>:
>> Anyway, off-screen rendering is still unsolved on Mac. To try wxGUI
>> Nviz extension, you should be able to compile nvizlib without rendec.c
>> (which is not needed for wxGUI).
> If you have to explicitly disable render.c, that suggests that
> something needs to be conditionalised. The code should at least
> compile on all platforms, even if it doesn't work.
> If you can't fix the compilation issues yourself, please post the
> error messages to the list.
I just don't have access to Mac to find out how to make off-screen
rendering working on this platform...
Relevant parts:
http://trac.osgeo.org/grass/browser/grass/trunk/lib/nviz/render.c#L106
http://trac.osgeo.org/grass/browser/grass/trunk/lib/nviz/render.c#L150
http://trac.osgeo.org/grass/browser/grass/trunk/lib/nviz/render.c#L188
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
